[Solved] AFG1062 no output with external triggered arbitrary burst
flov27
Post by flov27 » January 16th, 2018, 7:19 am
Hi there,
when I use a custom made arbitrary wave form, set the modulation to burst and the trigger source to external it is not possible to get any signal out of the device. The number of points is 500 and the set frequency 100 Hz. This happens with curves I uploaded from a computer and with curves I made manually at the AFG. With the preconfigured ones it works fine. Has anybody an idea how to get this running?
Best regards,
Flo
David N
Re: AFG1062 no output with external triggered arbitrary burst
Post by David N » January 17th, 2018, 8:59 am
This was a known limitation on AFG1062's that had firmware v1.0.4 or lower. This limitation has been resolved with the installation of firmware v1.0.5, which can be downloaded from Tek.com.
flov27
Post by flov27 » January 18th, 2018, 7:17 am
Thank you very much. With the new firmware it is working fine now.
Return to “AFG1000/2000/3000 series”
