Set File Transfer Direction
Burney2002
Country: Italy
Post by Burney2002 » July 18th, 2018, 3:46 am
Hi everybody.
I beg your pardon if the topic was already there, but I could not find him.
I'm working with a AFG3052C, and I sent to it a waveform using ArbExpress. It worked.
Then I changed some setup on the instrument and I saved the waveform on the internal memory. Now I'd like to transfer it to my PC, and file transfer and control menu, should work for that.
Unfortunately can't understand how to do that. I can do the opposite, transer file from PC to AFG, but I can't tranfer file from AFG to PC.
I guess It is possible to to that because that is what says the dialog window (see image attached).
Can anybody help me?
Regards, Claudio.
Re: Set File Transfer Direction
Post by David N » July 18th, 2018, 3:37 pm
The function of transferring a waveform from ArbExpress back to a PC is not supported for the AFG3252. You can save the modified waveform to a USB device and then import the waveform from the USB device to your PC>
Burney2002
Country: Italy
Post by Burney2002 » July 19th, 2018, 1:37 am
Ok, mystery solved.
Thank you very much David.
