Probe does not match test points
Kenson Ma
Post by Kenson Ma » August 23rd, 2016, 11:20 am
I am using a 3.5 mm probe to observe the gate signal of my MOSFET, but I want to use a 2.5 mm test point to reduce the size of the whole system. The probe just can not fit into the test point. Is there any ways that I can use the 2.5 mm test points? Thanks!
Re: Probe does not match test points
Post by David N » August 29th, 2016, 9:03 am
There were not adapters that would reduce the 3.5mm to 2.5mm. Would suggest looking for P6130/31/33/34/35/36 or P6230/31 probes on the used market. These probes were 2.5mm.
