BNC to BNC x10 probes
iayestaran
Country: France
Post by iayestaran » May 26th, 2021, 12:35 am
In an industrial project, I need to connect the 4 channels of my oscilloscope to 4 BNC connectors in a panel.
I need to use x10 probes, as my tension values might rise up to 160V.
Do this kind of x10 BNC to BNC probes exist?
If needed, I could replace the BNC connectors in the panel with other connector types. Is any alternative preferred over BNCs?
Thanks in advance.
AlexisMori
Re: BNC to BNC x10 probes
Post by AlexisMori » July 19th, 2021, 10:31 am
Hi...On the off chance that you are discussing the test connector, it is fine. Or possibly I approved of them.
On the off chance that you are discussing separate connectors, I don't have the foggiest idea, it will presumably rely upon the provider, however I would not depend on them being really excellent.
https://www.7pcb.com/
Last edited by AlexisMori on September 24th, 2021, 2:36 pm, edited 1 time in total.
Post by Andrea C » July 21st, 2021, 8:40 am
There are adaptors for your scope probe tip to be converted to BNC. Check your local electronics supply house.
You'd remove the spring loaded probe tip cover.
This blog entry has some ideas:
https://www.tek.com/blog/accurate-measu ... -probe-tip
