P6015A PROBE
kevin_david
Country: Colombia
P6015A PROBE
Post by kevin_david » June 16th, 2020, 2:20 pm
HI,
I am using a high voltage probe, specifically the TEKTRONIX P6015A but when measuring the voltage of 60 Hz waveform and a 1MHz waveform (Both has the same amplitude) the readings are very different, is this normal?.
Thanks.
Return to “High Voltage”
