TDP1000 can't auto zero on MSO58
OmironB
Country: Belgium
Post by OmironB » December 25th, 2020, 12:21 am
I have a TDP100 probe that works fine on an MSO4102B but can't auto zero on an MSO58. The offset voltage is around 280mV in the 4.25V range. If I put it in manual mode I can auto zero the 42.5V range fine, but not the 4.25 range.
Any ideas? Is the firmware on the MSO58 more strict about which offsets it accepts than earlier scopes? If so, why?
Return to “Differential”
