tekXL
m_w
tekXL
Post by m_w » February 1st, 2010, 2:20 am
Is there anyway I can get measurements from a saved REF A or cvs file or does it need to read from an active channel?
m_w
Re: tekXL
Post by m_w » February 1st, 2010, 2:42 am
also, when i turn ch1 on and press the measurement icon i get an error:
compile error
variable not defined
medHourMin id highlighted in visual basic debug mode.
tekuser
Re: tekXL
Post by tekuser » September 19th, 2017, 4:01 am
I got the same error message. All other panes of TekExcelToolbar.xla works except the TekExcelMeasurements.
How to define the medHourMin variable?
step480
Re: tekXL
Post by step480 » August 7th, 2018, 5:37 am
Hey, I am experiencing the same Problem. Did either of you work out how to fix this?
Thanks in advance.
