TDSxxx Repair Thread list
cgifool
Post by cgifool » December 12th, 2011, 2:16 pm
After wrestling with the lame search feature on the site looking for hints and tips repairing my TDS 640 acq errors, I decided to compile a list of all the threads I could find, in the hopes that it will help others in my position. Please post replies with any additional thread references!
TDS540 fault code
http://www1.tek.com/forum/viewtopic.php ... &sk=t&sd=a
TDS520 error log
http://www1.tek.com/forum/viewtopic.php ... 427&p=7032
TDS684A problems
TDS544A repair
TDS420 Acquisition error
TDS 640A Signal Path Compensation Failure
TDS544A project
TDS520 problem
TDS540 Flashing .9
Replacing capacitors TDS600A, TDS500A, and earlier
Adding Video Trigger to TDS744A
TDS644A NVram / Serial Parallel
http://www1.tek.com/forum/viewtopic.php ... 859&p=8637
TDS 524 screen stays blank (update 3dec2010)
TDS544A with damage to U1602 traces (failed ACQ board)
http://www1.tek.com/forum/viewtopic.php ... 214&p=6473
TDS 540 gray blank screen problem
http://www1.tek.com/forum/viewtopic.php ... 317&p=5300
TDS460 Trigger problems
http://www1.tek.com/forum/viewtopic.php ... 398&p=2795
TDS520 not boot
regards
David
Carl M
Re: TDSxxx Repair Thread list
Post by Carl M » December 19th, 2011, 11:25 am
stickied. thank you for doing this.
JVG
Post by JVG » January 30th, 2012, 3:11 am
I would add these:
TDS-524A does not power up
http://www1.tek.com/forum/viewtopic.php?f=5&t=4921
TDS-524A: damaged display?
http://www1.tek.com/forum/viewtopic.php?f=5&t=4926
Fixing a NuColor display
http://www1.tek.com/forum/viewtopic.php?f=5&t=4942
Hope they help!
JOSE
jayw_comark
Post by jayw_comark » December 5th, 2012, 2:59 am
For some reason, all the links seem to point to a TDS220 communication issue.
Is it just me or did something get screwed up?
Jay
andy
Post by andy » December 5th, 2012, 8:42 am
None of the links have ever worked for me either.
Carl M
Post by Carl M » December 14th, 2012, 12:31 pm
links work fine for me. don't know what to tell you.
Chris B
Post by Chris B » December 14th, 2012, 2:37 pm
Depending on where I am, and what browser I am using, sometimes the links do or do not work. You might be able to right click, copy the link location, then paste it into your browser address bar. Or it might be something in your cookies causing the problem.
picburner
Country: United Kingdom
Post by picburner » December 15th, 2012, 6:09 am
Andy is right the links does not work.
The reason is that the links lead to "http://www.tek.com/forum/..." when they should be "http://www1.tek.com/forum/..."
Probably inside the domain instead the links work normally.
If you try all work with this method.
Chris B
Post by Chris B » December 17th, 2012, 7:17 am
Ok, I have updated the links to be www1.tek.com. Please post if there are any further problems with the links.
picburner
Post by picburner » December 17th, 2012, 8:18 am
O.k. now all links in the cgifool post works well.
But still do not work the first two links of the JVG post while the third, despite having the same problem, lead in the right place.
Chris B
Post by Chris B » December 17th, 2012, 8:42 am
Thanks, I missed those. Updated now as well.
Payload
Post by Payload » January 26th, 2013, 11:53 am
Another story about a TDS540 with a happy ending :)
http://www1.tek.com/forum/viewtopic.php?f=5&t=5433
gooner
Country: South Africa
Post by gooner » August 2nd, 2017, 12:11 pm
Is there a problem with these links ? None of them work.
Post by David N » August 2nd, 2017, 3:46 pm
The forum has undergone changes since these posts were originally made. Some links that were added to posts back then may not work now in the present forum. The links in these posts were created by the forum users as the search at that time was not very useful. The search has been much improved so finding what you are looking for is much easier.
Igorkasona1233
Country: Australia
Post by Igorkasona1233 » March 4th, 2018, 7:36 pm
Why are All links dead? Why is this not updated or deleted ?
fenugrec
Country: Canada
Post by fenugrec » March 6th, 2018, 6:38 pm
The explanation and the solution are both in the post just above yours.
The search is far from perfect but it is adequate in this case. For example search for "adding video trigger", the first hit you get is the same thread:
viewtopic.php?f=568&t=136601
