help:TDS7104 recover CD or image...
rogerwu
Post by rogerwu » January 10th, 2013, 8:37 am
Today my friend asks for help. There is a problem with his TDS7104.
The TDS7104 can't start up. It seems this win2K system is crash. and I put thet Hard Disk out, then install a new win2K system on the new disk. but it's done not work.
major error is: no TI PCI 1225 card driver. so the tek's software can't start.
Is there somebody who have the recover CD of TDS7104 scope? or somewhere to download the system image?
thanks much.
Roger
Chris B
Re: help:TDS7104 recover CD or image...
Post by Chris B » January 10th, 2013, 8:44 am
The OS restore disks for these instruments are motherboard specific, and contain the drivers needed to talk to the acquisition hardware. If you have installed a retail version of Windows, it will run as a PC, but cannot talk to the acquisition hardware.
For the TDS7000 series, in the past you could order a replacement programmed drive as PN 050350214 (due to licensing issues, we do not provide downloads for the OS). I show that as no longer being available however. This instrument will probably need to be sent in to service for repair to have the OS restored.
nikig
Post by nikig » January 29th, 2013, 3:26 am
Hello, i have rebuild CD's for most TDS-5/6/7/8K series, just mail me PM.
Best regards.
NikiG
jeppe bastholm
Post by jeppe bastholm » May 13th, 2013, 2:43 am
Hi NikiG
I will be very happy if you can help me with a CD for restore operating system on a TDS7054.
Best regard
Jeppe Bastholm
Liquid Stranger
Post by Liquid Stranger » December 4th, 2014, 3:48 am
I also need a recovery CD for the TDS7104. is it available anywhere??
can anyone help??
thobie
Post by thobie » December 8th, 2014, 11:57 pm
I think I found the original recovery CDs for TDS7104 but still it informs "not correct system" (BL440ZX.EXE checking). What it is actually checking? However, I'm able to override this by "F8" on startup and not running this BL440ZX.EXE on autoexec.bat. But, now when running PQER.EXE recovery from image file (IMAGE.PQI), the image file seems to be password protected! Anyone know the password?
Or anyone know how the BL440ZX is actually checking the hardware version? I have changed the broken HDD, so could it be that - just something simple like volume name, or..? Someone good at decompiling .exe files? ;)
https://dl.dropboxusercontent.com/u/266 ... L440ZX.EXE
The CD is:
"TDS7000 Series Operating System Restor 063-3377-00"
cap
Post by cap » December 9th, 2014, 10:54 am
The restore software does a hardware check to verify that the expected hardware is present, if not it will stop. I would try it again with the exact drive model type, not just size. I have done this several times and it has always worked. For certain your motherboard must be the correct type (BL440) and with the tek firmware. The exact hardware fingerprint that the restore software is looking for is probably considered "Tektronix Confidential".
You can swap hardware into your system after the restore is complete, though as far as the scope performance goes don't expect much as the windows side does not impact the scope end that much, and who would use these as a PC anymore. Of course, to do a future restore, this hardware would need to be removed again. So make a image of the working drive and use that for future restore/transfer that onto a larger drive etc.
cap
curiosu
Post by curiosu » December 9th, 2014, 12:37 pm
These are the strings that are used:
char TEKTRONIX[] = "Tektronix";
char MORELICENSE[] = "more <license.txt";
char PQERPWDN[] = "PQER /PWD=N";
char IMGIMAGEPQI[] = "/IMG=IMAGE.PQI";
char CLS[] = "cls";
char INCORRECTSY[] = "Incorrect system! Press any key to reboot";
char KUEX[] = "KU440EX";
char KUEXMOTHERB[] = "KU440EX Motherboard Required! Press any key to reboot";
char BLZX[] = "BL440ZX";
char BLZXMOTHERB[] = "BL440ZX Motherboard Required! Press any key to reboot";
char REBOOT[] = "reboot";
After painful checks that I spare you it wants to execute this command:
PQER /PWD=N 16058 /IMG=IMAGE.PQI
This probably does something usefull, keep us informed please if something happened.
dryampy
Post by dryampy » January 7th, 2016, 2:44 pm
Dear Nikig,
I would also love to get the restore disc for a DPO TDS 7104 scope if possible, I tried to PM you but I just made this account and it will not let me access PM ability.
Thanks so much for your help!
-Yampy
snoopy
Country: Australia
Post by snoopy » August 30th, 2017, 6:53 am
Has anyone tried to download the firmware upgrade for this scope from the Tek website ? Seems to have been crippled by Tek !
https://www.tek.com/oscilloscope/tds705 ... re-upgrade
cheers
Post by David N » September 5th, 2017, 2:48 pm
I just checked and was able to successfully download the F/W upgrade file. Please try again.
snoopy
Country: Australia
Post by snoopy » September 9th, 2017, 6:20 am
Hi David
I keep getting a page with this response even if I am logged in or not. I am located in Australia. Does that make any difference ?
Regards
Software downloads for this product are screened in accordance with Tektronix policy. We will contact you within one business day.
If you feel you have reached this message in error or require further assistance, please contact your local Tektronix Customer Care Center.
Our regional phone numbers are listed below:
Canada, United States : 1-800-833-9200
Europe : 00800 2255 4835 (or 41 52 675 3777)
Japan : 0120-441-046
China, Hong Kong, Macau : 400-820-5835
Taiwan : 886 (2) 2722-9622
Korea : 82 (2) 6917-5000
India : 91 80 3079 2600
Singapore : (65) 6356-3900
Post by David N » September 11th, 2017, 2:22 pm
Have you completed a My Tek Account registration? If so, can you send me the email address you used via private message?
snoopy
Country: Australia
Post by snoopy » September 12th, 2017, 6:05 am
Hi David
yes I just sent you my details but it says the message is in the outbox and not sent ??? Not sure if it was actually sent although when I inspect the message it says it was sent at 9 PM my time.
regards
david
snoopy
Country: Australia
Post by snoopy » September 13th, 2017, 12:23 am
Hi David
Got a message from Tektronix saying that my login details were incomplete. So was able to download the file after I filled in the missing details and cleared the browser cache.
Regards
David
lucienmp
Country: Japan
Post by lucienmp » October 11th, 2017, 10:42 am
Best regards.
NikiG
I am also stuck in the same position, it seems the TekScope.exe is getting something off the disk I dont have from Vanilla OS + Firmware update.
Since I just signed up for an account its telling me I cant PM, can I reply to a PM from you - I desperately need the original Images / Disk Image
Cheers,
Luc
GETudury
Post by GETudury » September 18th, 2018, 10:14 am
NikiG,
would you able to place a link or email to contact you? Having issues with CSA8000 scopes..
Luc, did you got an image by any chance?
Gaston
