Error in code:SigType1_Sine_1K_90deg_ino
dalpets
Post by dalpets » July 11th, 2015, 5:16 am
In the Learn Digital Oscilloscope Operations using Arduino Board as DUT (Signal Generator) the above code passes an error, as follows. Could you please advise what coding corrections are necessary. Thank you.
Arduino: 1.6.4 (Windows XP), Board: "Arduino Uno"
C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10604 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files\Arduino\hardware\arduino\avr\variants\standard C:\DOCUME~1\THERIN~1\LOCALS~1\Temp\build1851337128202900342.tmp\SigType1_Sine_1k_90deg_ino.cpp -o C:\DOCUME~1\THERIN~1\LOCALS~1\Temp\build1851337128202900342.tmp\SigType1_Sine_1k_90deg_ino.cpp.o
SigType1_Sine_1k_90deg_ino.ino:14:1: error: 'include' does not name a type
SigType1_Sine_1k_90deg_ino.ino:22:1: error: expected declaration before '}' token
dalpets
Re: Error in code:SigType1_Sine_1K_90deg_ino
Post by dalpets » July 11th, 2015, 5:40 am
The complete code is as follows;
//____________________________________________________________________
// LEARNING DIGITAL OSCILLOSCOPE USING ARDUINO AS SIGNAL GENERATOR
// Date: 2013-12-01            Written by: Mukesh Soni
// Original code from Martin Nawrath (Germany): Single Sine Generator
// 2013-10-01: Modifie by Mukesh Soni to generate Dual Sine wave
// OUTPUT DETAILS
// Pin # 3  : Variable Duty Cycle PWM - For Sine Wave - 1kHz
// Pin # 11 : Variable Duty Cycle PWM - For Sine Wave - 1kHz/90 deg
include "avr/pgmspace.h"
  127,130,133,136,139,143,146,149,152,155,158,161,164,167,170,173,176,178,181,184,187,190,192,195,198,200,203,205,208,210,212,215,217,219,221,223,225,227,229,231,233,234,236,238,239,240,
  242,243,244,245,247,248,249,249,250,251,252,252,253,253,253,254,254,254,254,254,254,254,253,253,253,252,252,251,250,249,249,248,247,245,244,243,242,240,239,238,236,234,233,231,229,227,225,223,
  221,219,217,215,212,210,208,205,203,200,198,195,192,190,187,184,181,178,176,173,170,167,164,161,158,155,152,149,146,143,139,136,133,130,127,124,121,118,115,111,108,105,102,99,96,93,90,87,84,81,78,
  76,73,70,67,64,62,59,56,54,51,49,46,44,42,39,37,35,33,31,29,27,25,23,21,20,18,16,15,14,12,11,10,9,7,6,5,5,4,3,2,2,1,1,1,0,0,0,0,0,0,0,1,1,1,2,2,3,4,5,5,6,7,9,10,11,12,14,15,16,18,20,21,23,25,27,29,31,
  33,35,37,39,42,44,46,49,51,54,56,59,62,64,67,70,73,76,78,81,84,87,90,93,96,99,102,105,108,111,115,118,121,124
#define cbi(sfr, bit) (_SFR_BYTE(sfr) &= ~_BV(bit))
#define sbi(sfr, bit) (_SFR_BYTE(sfr) |= _BV(bit))
int ledPin = 13;                 // LED pin 7
int testPin = 7;
int t2Pin = 6;
byte bb;
double MY_FREQ;
int MY_PHASE;
// const double refclk=31372.549;  // =16MHz / 510
const double refclk=31376.6;      // measured
// variables used inside interrupt service declared as voilatile
volatile byte icnt;              // var inside interrupt
volatile byte icntNew;              // var inside interrupt
volatile byte icnt1;             // var inside interrupt
volatile byte c4ms;              // counter incremented all 4ms
volatile unsigned long phaccu;   // pahse accumulator
volatile unsigned long tword_m;  // dds tuning word m
void setup()
  pinMode(ledPin, OUTPUT);      // sets the digital pin as output
  Serial.begin(115200);        // connect to the serial port
  Serial.println("DDS Test");
  pinMode(6, OUTPUT);      // sets the digital pin as output
  pinMode(7, OUTPUT);      // sets the digital pin as output
  pinMode(11, OUTPUT);     // pin 11: SINE WAVE 1 = PWM  output / frequency output
  pinMode(3, OUTPUT);     // pin 3: SINE WAVE 2 = PWM  output / frequency output
  Setup_timer2();
  // disable interrupts to avoid timing distortion
  cbi (TIMSK0,TOIE0);              // disable Timer0 !!! delay() is now not available
  sbi (TIMSK2,TOIE2);              // enable Timer2 Interrupt
  MY_FREQ=1000.0;                    // initial output frequency = 1000.o Hz
  tword_m=pow(2,32)*MY_FREQ/refclk;  // calulate DDS new tuning word
void loop()
  MY_FREQ = 1000.000;        // SET Frequency
  MY_PHASE = 90;             // SET Phase (0-360 degree)
  icntNew = map( MY_PHASE, 0, 360, 0, 255);
  while(1) {
     if (c4ms > 250) {                 // timer / wait fou a full second
      c4ms=0;
      cbi (TIMSK2,TOIE2);              // disble Timer2 Interrupt
   sbi(PORTD,6); // Test / set PORTD,7 high to observe timing with a scope
   cbi(PORTD,6); // Test /reset PORTD,7 high to observe timing with a scope
   analogWrite(9,127);
// timer2 setup
// set prscaler to 1, PWM mode to phase correct PWM,  16000000/510 = 31372.55 Hz clock
void Setup_timer2() {
// Timer2 Clock Prescaler to : 1
  sbi (TCCR2B, CS20);
  cbi (TCCR2B, CS21);
  cbi (TCCR2B, CS22);
  // Timer2 PWM Mode set to Phase Correct PWM
  cbi (TCCR2A, COM2A0);  // clear Compare Match
  sbi (TCCR2A, COM2A1);
  // Timer2 PWM Mode set to Phase Correct PWM for wave 2
  cbi (TCCR2A, COM2B0);  // clear Compare Match
  sbi (TCCR2A, COM2B1);
  sbi (TCCR2A, WGM20);  // Mode 1  / Phase Correct PWM
  cbi (TCCR2A, WGM21);
  cbi (TCCR2B, WGM22);
// Timer2 Interrupt Service at 31372,550 KHz = 32uSec
// this is the timebase REFCLOCK for the DDS generator
// FOUT = (M (REFCLK)) / (2 exp 32)
// runtime : 8 microseconds ( inclusive push and pop)
ISR(TIMER2_OVF_vect) {
  sbi(PORTD,7);          // Test / set PORTD,7 high to observe timing with a oscope
  phaccu=phaccu+tword_m; // soft DDS, phase accu with 32 bits
  icnt=phaccu >> 24;     // use upper 8 bits for phase accu as frequency information
                         // read value fron ROM sine table and send to PWM DAC
  OCR2A=pgm_read_byte_near(sine256 + icnt);
  OCR2B=pgm_read_byte_near(sine256 + byte(icnt + icntNew ));
  if(icnt1++ == 125) {  // increment variable c4ms all 4 milliseconds
    c4ms++;
    icnt1=0;
 cbi(PORTD,7);            // reset PORTD,7
israelsteel
Country: Israel
Post by israelsteel » March 8th, 2017, 7:54 am
I have an error trying to upload this to the arduino...it is in reference to the line
PROGMEM prog_uchar
The error is "prog_uchar does not name a type
How can I correct this?
Carl M
Post by Carl M » March 20th, 2017, 11:26 am
@daplets - the code you posted is in error. the code included with the download is correct. i suggest you download a new copy: http://www.tek.com/lab-course/learn-dig ... -generator
@israelsteel - this happens when you use Arduino IDE v1.6.12 or similar. i suggest you try Arduino IDE v1.0.6.
