How to use oscilloscope with floating grounds?
Vince W
Re: How to use oscilloscope with floating grounds?
Post by Vince W » November 23rd, 2016, 10:12 am
Yes, the best solution is to use true differential probes. It is generally not good practice to connect your measured signal's ground to earth (chassis) ground.
Post by David N » November 28th, 2016, 9:27 am
If your TPS2014 has the bandwidth you need, but you need 4 isolated channels, you can consider the TPS2024B. The TPS2024B has four isolated channels.
ditizona
Country: Spain
Post by ditizona » November 30th, 2016, 7:02 am
Yes, differential probes will do the trick. Althouhg those don't provide true isolation, just a high impedance in between grounds
Post by David N » November 30th, 2016, 1:12 pm
If the application need is for a complete galvanic isolation, look at the new Tektronix IsoVu™ probes. They use optical communications and power-over-fiber for complete galvanic isolation. See URL: http://www.tek.com/isolated-measurement-systems
