Need to found yet more obscure TDS 5xx Software
albus95
Country: Italy
Post by albus95 » May 3rd, 2021, 8:19 am
I was able to get my hand on some of the pages of the TDS544A Technical manual vol 1 because my interest was to found how to run the various diagnostic procedures that the famous TDS520 CM Vol 2 manual refer. To my complete amusement I realized that the procedure are executed by a software made by Tek that communicate to the scope via GPIB (or RS232 apparently) when a set of dip switches are selected. To make the thing even funnier apparently in the software there was some description on what each procedure does. So basically the manual I have is useless unless I have the proper software. I will attach the page where the manual speak about this software:
https://www.dropbox.com/s/3yllrsa6dwf ... .PNG?dl=0
https://www.dropbox.com/s/u01h91trorhy ... .PNG?dl=0
https://www.dropbox.com/s/5fsj18k84728 ... .PNG?dl=0
Does anyone of the member of the forum that work at tektronix is able to dig out this software because I'm almost sure that is available no where as all of this technical manuals.
