Python Socket Control 1
Carl M
Post by Carl M » November 20th, 2009, 5:03 pm
For the instruments that support it.
## Python Socket Control 1
# Date: 09-15-2009
# Demonstrate how to communicate with Tektronix instruments using an TCP socket
# connection.
# COMPATIBILITY
# All Windows based instruments with TekVISA v3.2 or later
# AWG400, 500, 600, 700
# TESTED & DEVELOPED
# Microsoft Windows XP SP3
# Python v2.6
# Ethernet (DHCP)
# DPO7254 FW v4.3.5 Build 6
# Tektronix provides the following example "AS IS" with no support or warranty.
import socket
input_buffer = 2 * 1024
s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
s.connect(("134.62.63.56", 4000))
cmd = "*idn?" + "\n"
s.send(cmd)
id = s.recv(input_buffer)
print id
cmd = "*rst" + "\n"
s.send(cmd)
s.close()
springday
Re: Python Socket Control 1
Post by springday » August 23rd, 2010, 4:24 pm
When I tried your example, I got an error message saying:
'No connection could be made because the target machine actively refused it'
How can I get around that?
Thanks.
springday
Post by springday » August 24th, 2010, 10:32 am
I got around the previous error message.
Now I have another question. I have the following code to try to get hardcopy from the o'scope:
        self.write("HARDCOPY:PORT ETHErnet")
        self.write("HARDCOPY:FORMAT BMP")
        self.write("HARDCOPY START")
        self.write("*WAI")
        fOut = file('tds.bmp', 'wb')
        wf = self.inst.recv(65536)
        fOut.write(wf)
        fOut.close()
However, what I received from the scope was:
...HTTP/1.1 100 Continue
I had no problem with the code when I communicated with the scopy via GPIB module. Now I am hoping to do the same thing over Ethernet. How can I get a hardcopy of scope screen image via a socket?
Carl M
Post by Carl M » September 9th, 2010, 4:21 pm
springday wrote:When I tried your example, I got an error message saying:
Thanks.
firewall? socket server not started? wrong ip address? there are countless reasons why network connections are refused.
Carl M
Post by Carl M » September 9th, 2010, 4:24 pm
you cannot just connect to the first open port you find. your talking to a web server (likely escope). i doubt your instrument has socket support.
# COMPATIBILITY
Lei_ZTR_Control
Country: Canada
Post by Lei_ZTR_Control » October 10th, 2018, 1:32 pm
Hi Carl,
I am using your program test my system. When I run the code, I constantly get the following response from TBS2000. Can you please advise what can go wrong here? I am using Python3.7 and just changed the cmd with encode() method and the id with the decode() method.
Many thanks.
Lei
UNKNOWN 400 Bad Request
Server: thttpd/2.25b 29dec2003
Content-Type: text/html; charset=UTF-8
Date: Wed, 10 Oct 2018 16:15:50 GMT
Last-Modified: Wed, 10 Oct 2018 16:15:50 GMT
Accept-Ranges: bytes
Connection: close
Cache-Control: no-cache,no-store
<HTML>
<HEAD><TITLE>400 Bad Request</TITLE></HEAD>
<BODY BGCOLOR="#cc9999" TEXT="#000000" LINK="#2020ff" VLINK="#4040cc">
<H2>400 Bad Request</H2>
Your request has bad syntax or is inherently impossible to satisfy.
<HR>
<ADDRESS><A HREF="http://www.acme.com/software/thttpd/">thttpd/2.25b 29dec2003</A></ADDRESS>
</BODY>
</HTML>
Lei_ZTR_Control
Country: Canada
Post by Lei_ZTR_Control » October 11th, 2018, 9:54 am
This has been solved. The issue was the firmware in the scope does not support sockets. After upgrading the firmware, it's working now.
Thanks.
