AWG5000 ArbExpress Matlab 'matarb error'
sandiego
Post by sandiego » June 18th, 2010, 4:29 pm
I'm going thru the ArbExpress manual. On page 151 it explains how to connect thru a LAN connection using Matlab.
ArbExpress is working fine over the LAN by itself. I get this error message when I try to connect using Matlab:
>> [SessionID, StatusMsg] = NewSession ('TCPIP::10.79.6.8::INSTR','LAN')
??? Undefined function or method 'matarb' for input arguments of type 'char'.
Error in ==> C:\Program Files
(x86)\Tektronix\ArbExpress\Tools\Matlab\NewSession.p>NewSession at 3
I have ArbExpress\Tools\Matlab in the path.
matarb.dll is a dll file and I don't see any other matarb files.
NewSession is a p file (encrypted) so I don't know what line 3 is.
sandiego
Re: AWG5000 ArbExpress Matlab 'matarb error'
Post by sandiego » June 19th, 2010, 11:14 am
I'm using Windows XP 64 if that makes any difference.
sandiego
Post by sandiego » June 19th, 2010, 11:18 am
Maybe there is something wrong with my path:
http://www.mathworks.de/matlabcentral/n ... ead/166200
sandiego
Post by sandiego » June 21st, 2010, 9:33 am
Is it possible that the 32-bit dll's don't work on Windows 64?:
It can be a problem: http://www.dnjonline.com/article.aspx?i ... access3264
Carl M
Post by Carl M » June 21st, 2010, 10:24 am
the *.p files are protected *.m files. I do not have the source, nor do I know who wrote them.
why not just make a VISA object and talk directly to the instrument? http://www.tek.com/forum/viewtopic.php?f=6&t=1784
also note ArbExpress' Download Agreement: http://www.tek.com/Measurement/Support/ ... ement.html
Carl M
Post by Carl M » June 21st, 2010, 10:26 am
i don't have a 64-bit operating system to test this but I'm not sure if the *.p files require a 32-bit visa... which i don't think you can have/use on 64-bit windows.
sandiego
Post by sandiego » June 21st, 2010, 10:31 am
ArbExpress uses two DLL files for matlab support. They are Arbether.dll and matarb.dll.
The problem so far is with the matarb.dll file. The other one may also be a problem but I haven't gotten that far.
I may just swithc to a 32-bit machine and see how that works.
I may try one of your other suggestions too.
sandiego
Post by sandiego » June 21st, 2010, 12:16 pm
I tried this suggestion and I got the same type of error message: http://www.tek.com/forum/viewtopic.php?f=6&t=1784
Time to switch back to Windows 32-bit computer. I'm sure it will work then.
sandiego
Post by sandiego » June 21st, 2010, 12:22 pm
TekVISA only works on 32-bit Windows: http://www2.tek.com/cmswpt/faqdetails.l ... 6253&lc=EN
Gerard
Post by Gerard » September 9th, 2013, 6:26 am
I have the same problem and I wonder if a solution has been found.
I'm using Windows 8, 64 bits, Matlab 2013a. With the software included in the CDrom (that is, ArbExpress and TekVisa), I couldn't generate any waveform (even a simple sine) and the USB driver did not work either. I downloaded the latest version of both programs (ArbExpress 2.9 2013.04.16, TekVisa v4.0.0.80), and everything works fine.
However, I still have this message from Matlab that does not allow me to launch the sample code.
Warning: The P-code file NewSession.p was generated prior to MATLAB version 7.5 (R2007b) and
will not be supported in a future release. Use pcode to regenerate NewSession.p using MATLAB
R2007b or later.
> In sample at 15
Undefined function 'matarb' for input arguments of type 'char'.
Error in C:\Program Files (x86)\Tektronix\ArbExpress\Tools\Matlab\NewSession.p>NewSession
(line 3)
Error in sample (line 15)
s=NewSession('USB0::0x0699::0x0343::JU010107::INSTR','usb');
The first message is "just" a warning, but the undefined function error is critical.
Has anybody gone through the same problem?
Thank you.
