How to edit the right TXT file to import my wave?
OttawaRan
Post by OttawaRan » August 8th, 2013, 11:35 am
Dear Technical Support:
I edit a 4-level electrical signal in Matlab, and then I want to import my wave into the Tektronix 7000 AWG, and I find the only file format can be read is .txt format (because other file format is from AWG400/500 etc.), so I create a txt file, and writes as follows" x=[0 1 1 2 2 3 4 4 5 5 6 7 8 8 9 9 10 11 11 12 12 13 14];
y=[-0.5 -0.5 1 1 0.5 0.5 0.5 -1 -1 -0.5 -0.5 -0.5 -0.5 1 1 0.5 0.5 0.5 -1 -1 -0.5 -0.5 -0.5];", and x is the time slot, y is the vertical axis and unit is volts. So this is my Matlab 4-level signal x and y axis.
But the AWG write "File E:\4-level electrical signal . txt wrong format", and it is really upset. So I want to know how to edit the right txt file to import my signal into the AWG and make it works.
Look forward your suggestions and answers!
Regards!
Ran
8-8-13
Carl M
Re: How to edit the right TXT file to import my wave?
Post by Carl M » August 20th, 2013, 10:41 am
for AWG7000, i've never had a problem with one sample per line. you do need dos style newlines and ascii encoding
