AFG3021B works with ArbExpress?
alani
Post by alani » September 27th, 2013, 9:01 am
Hello Tech Support,
I need to generate a signal based on some requirments and time is crucial.
I am currently considering purchasing the AFG3021B, but I want to verify with the applications team:
Does ArbExpress work with this signal generator?
Does Tek sell the GPIB?
Thank you for the support.
Alani
Re: AFG3021B works with ArbExpress?
Post by David N » September 27th, 2013, 10:50 am
Hello Alani,
Yes ArbExpress supports the AFG3021B. The AFG3021B and it successor the AFG3021C both support GPIB, USB and LAN connectivity. ArbExpress is supplied as a standard accessory to these products. You can refer to the AFG3021B data sheet at http://www.tek.com/datasheet/signal-gen ... generators and the AFG3021C data sheet at http://www.tek.com/datasheet/signal-gen ... -datasheet.
You can also download the ArbExpress software at http://www.tek.com/axw100-software/arbe ... ing-sw-v25.
alani
Post by alani » September 27th, 2013, 12:37 pm
Hi Hiker,
Do you have a software example library?
IE, an example on PWM and controlling: duty cycle, frequency, rise time, fall time, High level, Low level?
Post by David N » September 27th, 2013, 4:57 pm
We do not have a software example library.
