AFG3000 translate code into Python
muggle
Post by muggle » November 26th, 2013, 2:55 pm
I'm trying to write a Python code that goes like Example 2 (section 4-4) in the AFG3000 manual. If I'm not mistaken, this generates a Gaussian wavepacket-type shape.
I want to produce a series of these waveforms for a specific duration with a specific period between individual waveforms (at say, 80MHz and maximum amplitude 5 V). Later on, I need to modify the maximum amplitude according to a function of time (say, cos(kt)). (Just note that I'm a beginner Python user, so I'm really in the deep end with all this coding :) )
I'm using AFG3252.
Chris B
Re: AFG3000 translate code into Python
Post by Chris B » December 23rd, 2013, 7:56 am
I have a posted code example here of creating a waveform (with various length pulses) here:
http://www1.tek.com/forum/viewtopic.php?f=6&t=4933
You an ignore all of the waveform creating part of the code, and put in what you need. The scaling of the waveform and transferring it you can probably leave as is. For the actual amplitude, and frequency that you play back the waveform, these you set that after the waveform is in EMEM on the AFG. Granted, you can send the SCPI commands to set that if needed (for example, you can set the frequency to play back, calculating it as needed based on the sample rate you need the waveform to play at vs. the number of points in your waveform)
