I have a Problem. How can I calculate the SNR from a signal generated by a AFG 3022b. I do not now how it is posible because I only have the noise level, which I can change.
AFG 3022b SNR calculation
Jump to
- Announcements
- Customer Support
- ↳ Product Support
- ↳ Oscilloscopes
- ↳ Programming Support
- ↳ Passive/Low Voltage
- ↳ High Voltage
- ↳ Differential
- ↳ Current
- ↳ Signal Sources
- ↳ AFG1000/2000/3000 series
- ↳ AWG5000/7000/70000 Series
- ↳ Keithley 3390
- ↳ TSG4100A Series
- ↳ Spectrum Analyzers
- ↳ Announcements and FAQs
- ↳ RSA Programming
- ↳ RSA5000/6000 Series
- ↳ Vector Network Analyzers
- ↳ TTR500 Series VNAs
- ↳ 2600 Series SourceMeter
- ↳ 2400 Series SourceMeter
- ↳ DMM6500 Bench/System DMM
- ↳ Other DMM's
- ↳ 7000 Series Switch
- ↳ 700 Series Switch
- ↳ RF Switch
- ↳ Other Switches
- ↳ Power Supplies
- ↳ Series 2300
- ↳ Other Power Supplies
- ↳ Power Analyzers
- ↳ ACS Software Products
- ↳ Nanovoltmeters
- ↳ Electrometers
- ↳ Curent Amplifiers
- ↳ PicoAmmeters
- ↳ Current Sources
- ↳ Bit Error Rate Testers
- ↳ Logic Analyzers
- ↳ Video Test
- ↳ Other Instruments
- ↳ Electronic Loads
- ↳ Frequency Counters
- ↳ Software
- ↳ TekScope Anywhere
- ↳ SourceXpress
- ↳ SignalVu-PC
- ↳ PWRVIEW
- ↳ KickStart
- ↳ Test Script Builder
- ↳ LabView Drivers
- ↳ IVI Drivers
- ↳ TekVISA
- ↳ ExcelLINX
- ↳ IVy
- ↳ Keithley I/O Layer (KIOL)
- ↳ Accessories
- ↳ Test Fixtures
- ↳ Cables and Connectors
- ↳ Application Support
- ↳ Low Current Measurements
- ↳ Low Voltage Measurements
- ↳ Resistivity Measurements
- ↳ Hall Measurements
- ↳ Electrochemistry
- ↳ Solar Cell Measurements
- ↳ High Brightness LEDs
- ↳ General Discussion
