AWG70K MATLAB ICT Send Waveform Example
Grant B
Post by Grant B » March 6th, 2014, 11:19 am
%% Waveform Sample Data Calculation - Pure Matlab
freq = 10;
per = 1/freq;
cycles = 100;
SR = 100;
t = 0:1/SR:cycles*per-1/SR;
w = freq*2*pi;
a = sin(1/freq*pi*t);
y = single(a.*sin(w*t));
waveform_data = y;
%plot(t,y);
%% Opening VISA Session
visa_vendor = 'ni';
visa_address = 'TCPIP::134.62.36.57::INSTR';
buffer = 1024*4*10;
awg = visa(visa_vendor, visa_address, 'OutputBuffer', buffer);
fopen(awg);
%% Funtional Check
query(awg,'*idn?')
fwrite(awg, '*cls')
fwrite(awg, '*rst')
%% Pretest Error Check
query(awg,'*esr?')
query(awg,'syst:err?')
%% Waveform Send
waveform_name = 'test';
delete_waveform = sprintf('wlist:waveform:delete "%s"', waveform_name);
header = sprintf('#%d%d',length(num2str(length(waveform_data))), 4*length(waveform_data));
create_waveform = sprintf('wlist:waveform:new "%s", %d', waveform_name, length(waveform_data));
write_waveform_binblock = sprintf('wlist:waveform:data "%s", %s', waveform_name, header);
end_line = 10;
assign_waveform_ch1 = sprintf('source1:waveform "%s"', waveform_name);
fwrite(awg, delete_waveform);
fwrite(awg, create_waveform);
fwrite(awg, write_waveform_binblock);
fwrite(awg, waveform_data, 'single');
fwrite(awg, end_line);
fwrite(awg, assign_waveform_ch1);
%% Post Test Error Check
query(awg,'*esr?')
%% End VISA session
fclose(awg);
delete(awg);
clear
Griz
Carl M
Re: AWG70K MATLAB ICT Send Waveform Example
Post by Carl M » September 4th, 2014, 11:07 am
found a bug
should be:
header = sprintf('#%d%d',length(num2str(4*length(waveform_data))), 4*length(waveform_data));
personally i'd add a line and variable to improve readability
waveform_bytes = length(waveform_data) * 4;
header = sprintf('#%d%d', length(num2str(waveform_bytes)), waveform_bytes);
