Matlab - Save in WFM format
azham
Post by azham » June 9th, 2014, 12:35 am
I would like to know any codes available to save WFM format in MATLAB
I've tried finding on the net but none available
Azham
Carl M
Re: Matlab - Save in WFM format
Post by Carl M » June 9th, 2014, 11:49 am
i think you are looking for: http://www1.tek.com/forum/viewtopic.php?f=6&t=2555
this is part of the code examples sticky: http://www1.tek.com/forum/viewtopic.php?f=8&t=1789
azham
Post by azham » June 10th, 2014, 11:47 pm
I've tried the code given. Failed to open in ArbXpress.
I checked the output and compared with a correct .wfm
So i've tweak abit so it save properly.
The data needs to be in binary and \n seems to create a new line in the data
Hope it helps anyone trying to find this
%% variables
samples = 262000;
filename = 'O_262Kpts.WFM';
count = 1;
%% create test waveform
wave = -2.*rand(samples, 1)+1;
sample_bytes = num2str(samples*5,'%d');
length_bytes = num2str(length(sample_bytes));
header = ['#' length_bytes sample_bytes];
%% file operations
fid = fopen(filename, 'wt');
fwrite(fid, 'MAGIC 1000');
fprintf(fid, '\n');
fclose(fid);
fid = fopen(filename, 'a');
fwrite(fid, header);
while (count <= samples)
    fwrite(fid, wave(count), 'float');
    fwrite(fid, ' ');
    count = count + 1;
end
fwrite(fid, 'CLOCK 1.10e+8');
fclose(fid);
fid = fopen(filename, 'at');
fprintf(fid, '\n');
fclose(fid);
Carl M
Post by Carl M » June 11th, 2014, 2:20 pm
assuming that ArbExpress, no-cost software provided AS-IS, is the "correct" *.wfm file format is... a dangerous assumption.
i define what is correct as what accomplishes your task. i'm glad you were able to find a solution and thank you for sharing.
azham
Post by azham » June 11th, 2014, 8:42 pm
so the .wfm i got from the samples inside the ArbXpress is not a good comparison for a correct way to save .wfm?
Will it cause conflict if i run the file on a AWG?
I havent tested in on a physical AWG just checked with ArbXpress for verification.
Carl M
Post by Carl M » June 17th, 2014, 2:33 pm
AWG *.WFM files are used with the AWG400/500/600 (hundred) Series. The byte definitions are documented in the AWG400/500/600 Series Programmer Manual - Waveform File page 2-131 (161 of PDF) (http://www.tek.com/node/831025). awg5k/7k and the new awg70k support importing these old *.wfm to ease migration to new equipment but they have new formats as well.
