I Q Modulation with AWG
azham
Post by azham » June 11th, 2014, 8:52 pm
I have a baseband I and Q data recorded from RSA and playback with the XCOMsystem playback system.
How do we modulate the I Q baseband data with the AWG?
Are we able to to straight away connect the Analog I & Q (from XCOM IQC5000A) to the AWG and output the RF back?
If not? How can i utilized the AWG to generate back the RF signal from the IQ data
Ive checked the RFXpress but there is no option to select if i wanna use my own I Q data
Carl M
Modulating IQ with RFXpress
Post by Carl M » June 17th, 2014, 10:13 am
in rfxpress set your modulation type to file1(samples) and choose your sample file. if i and q are separate files you'll need to switch to multi-carrier mode; two carriers, same frequency, one for i and one for q.
azham
Re: I Q Modulation with AWG
Post by azham » July 9th, 2014, 8:26 pm
Thanks for the reply,
Im trying with RFXpress now and getting weird result.
Do i need to change the phase as well for the Q data?
