AFG3101
PYS007
AFG3101
Post by PYS007 » August 15th, 2014, 7:14 am
Hello, I have two AFG3101 generator, and one generator flashes very short some LEDs on the front-panel, if I rotate the wheel knop. Is it normal, or is it a failure ?
With the old Firmware V3.0.x the generator hangs up some times.
Firmware is now V3.2.3 and I have tested one hour with no hung up, but the LED flashes on the wheel knop action is still present some times.
thanks for help,
Sascha
Carl M
Re: AFG3101
Post by Carl M » August 18th, 2014, 1:15 pm
which led flashes? does this always occur or only with specific settings?
