AFG3022 Changing amplitude and offset
hithesh123
Post by hithesh123 » August 24th, 2014, 11:55 pm
Is there a way to change amplitude and offset at the same time.
Let's say I need a signal with variable amplitude from 1Vpk-pk to 5Vpk-pk
Offset should change accordingly from 0.5 to 2.5v.
This is for a sine wave.
Carl M
Re: AFG3022 Changing amplitude and offset
Post by Carl M » August 25th, 2014, 2:11 pm
define "same time". Within a millisecond or a nanosecond?
hithesh123
Post by hithesh123 » August 27th, 2014, 2:45 am
Same time - within nanoseconds would be great. But I can settle for milliseconds.
Carl M
Post by Carl M » August 29th, 2014, 5:01 pm
you can send concatenated programmatic commands. it takes about 100 ms and the output will have aberrations especially if you are crossing attenuator banks.
:source1:voltage:offset 1;:source1:voltage 2;
:source1:voltage:offset -1;:source1:voltage 1;
for uncompromising control of your output, you'll need an AWG.
Users browsing this forum: Bing [Bot] and 1 guest
