channel skew function in AWG7122B
jo.thalbach
Post by jo.thalbach » January 19th, 2015, 6:55 am
AWG7122B has a function "Channel skew" and the signals can also be shifted with the function "Horizontal shift/rotate". I think these two are similar and can achieve the same effect. Is it true?
Jo
Re: channel skew function in AWG7122B
Post by David N » January 21st, 2015, 5:08 pm
These functions are different from each other. The Channel Skew adjustment allows the timing (delay) between two output waveforms to be offset from one another. The Horizontal Shift/Rotate is used when editing a waveform file. It allows a specified range of data in the waveform file to be shifted or rotated.
