MDO3024 and AUTOSET
angelo
Country: Brazil
MDO3024 and AUTOSET
Post by angelo » February 11th, 2019, 8:33 am
I don´t understand the autoset feature or something is wrong with my code.
I have a sine wave (1 Vpp with 0.1s period) entering CH1 of the scope. If I send the autoset command nothing happens. The horizontal axis keeps at 4 usec.
here is my code
' Configure MDO
CWVisa1.Write (":Data:Source CH1")
CWVisa1.Write (":Data:Start 1")
CWVisa1.Write (":DATa:STOP 10000")
CWVisa1.Write (":DATa:ENCdg RPB")
CWVisa1.Write (":HEADer 0")
CWVisa1.Write (":AUTOSet:ENAble 1")
CWVisa1.Write (":AUTOSet EXECute")
CWVisa1.Write (":ACQuire:MODe SAMple")
CWVisa1.Write (":ACQUIRE: STOPAFTER SEQUENCE")
CWVisa1.Write (":ACQUIRE:STATE RUN")
Re: MDO3024 and AUTOSET
Post by David N » February 11th, 2019, 4:30 pm
Your 0.1 second period signal is too slow for the auto set function to work. Try your same code, but attach a scope probe to the "probe comp" signal and see if autoset in your program works.
angelo
Country: Brazil
Post by angelo » February 12th, 2019, 12:20 pm
Hi David.
I would like to thank you for your support.
After your post, I checked that the minimum freq. to autoset is around 166.68Hz.
Now everything seems to be working.
Regards,
Angelo
