TV220/ConvertTekWfm Question
glubash
Post by glubash » February 8th, 2011, 1:02 pm
Hello, I have a TV220 "CableScout" TDR that I purchased a number of years ago (1998?). I managed to pull a .wfm file off of it using a serial cable but am unable to get ConvertTekWfm to work. I've been using the command line:
ConvertTekWfm tsf0005.wfm /csv
After I enter this, all I get in return is "Usage: ConvertTekWfm [ /? | InputFile....."
Two questions: 1) Do I have the syntax correct? 2) Is the .wfm file from the TV220 supported by ConvertTekWfm?
I have been using version "cnvrtwfm_2008.06.09.09.48.57_5043_EN.zip".
Thanks in Advance!
Glubash
Carl M
Re: TV220/ConvertTekWfm Question
Post by Carl M » March 1st, 2011, 3:38 pm
says it only works with TDS400, TDS500, TDS600 and TDS700 Series oscilloscopes. no mention of the TV220.
Users browsing this forum: Bing [Bot] and 5 guests
