Acquisition Bandwidth on RSA6100A
asherlk1
Post by asherlk1 » July 19th, 2011, 10:34 am
Can the acquisition bandwidth be set to 30MHz? The bandwidth now jumps from 20MHZ to 40.
Chris B
Re: Acquisition Bandwidth on RSA6100A
Post by Chris B » July 19th, 2011, 12:21 pm
No, it cannot. The sample rate is restricted by the available sample rates. In this case you are jumping from 12.5MS/s to 25MS/s. There is not a setting between them.
asherlk1
Post by asherlk1 » July 19th, 2011, 12:44 pm
So, just to reiterate, there is absolutely no way to set the acquisition bandwidth to 30MHz?
Thanks for your reply!
w2aew
Post by w2aew » August 12th, 2011, 12:50 pm
asherlk1 wrote:So, just to reiterate, there is absolutely no way to set the acquisition bandwidth to 30MHz?
That is correct. However, the ANALYSIS bandwidth can be set to 30MHz, even though the acquisition BW in that case would be 40MHz.
Users browsing this forum: No registered users and 19 guests
