WVR 7000 series NTP Sync connection
june786
Post by june786 » July 26th, 2011, 10:32 pm
Hello
We have atleast x20 WVR 700 series Rasterizers connected in a network enviroment.
A request has come through the internal clock, Tektronix suggested using NTP clock from the current IP connection which uses a subnet of that current IP address.
This is to monitor logs if we had a porblem with a video/audio clip, so we could go back to the time as analyse logs.
Is there a documentation some where which i could refer too? Or what is the procedure?
Thanking youin advance
Z
stampy
Re: WVR 7000 series NTP Sync connection
Post by stampy » August 2nd, 2011, 1:04 pm
Z,
There is no NTP clock available for our waveform monitor / rasterizers. It uses either VITC or LTC.
Regards,
Dan
Tektronix Applications Engineer
Video Product
june786
Post by june786 » August 11th, 2011, 1:18 pm
I will wire this up for LTC..
Thanks once again
