TimeVIEW FCA3100 time interval measurements
mark.daly
Post by mark.daly » October 12th, 2011, 6:54 am
I want to know if I can use the FCA3100 to measure the time interval between a start pulse at A and a stop pulse at B. I've been reading over the manuals etc. and I am unsure about what it can do. It looks like the device has the resolution I need, I would need approximately 1ns resolution,the lower the better, but I don't know if it is possible to record the time intervals between the pulses continously and export them so I could create a histogram using the TimeVIEW software. Maybe it is possible with the provided LabVIEW drivers? If anyone could clear this up for me it would be great.
I'm looking to use the device for photon correlation, if that is of any help.
Carl M
Re: TimeVIEW FCA3100 time interval measurements
Post by Carl M » October 21st, 2011, 1:51 pm
i don't have access to a FCA3100, nor have I used one for the purpose you've described.
could you contact your local distributor for a demonstration? this way you can test it yourself.
w2aew
Post by w2aew » October 28th, 2011, 12:27 pm
mark.daly wrote:Hello,
It looks like the FCA3000 series can do what you want. If you select the Measurement type as "Time", then you can select "Time Interval" as the function, then select one of the following: "A to B", "A to A", "B to A", or "B to B". I would also assume that the TimeVIEW software would support the logging of this measurement. Also, the instrument itself can provide you with Statistics, a histogram, or even a time-trend plot of this measurement.
Users browsing this forum: No registered users and 10 guests
