TekVisa in Visual Basic 2010
MIS
Post by MIS » January 26th, 2012, 9:06 am
How i can use TekVisa in Visual Basic 2010, which .dll I need to integrate ?
I want to read the lockStatus from the InstrumentManager -> Properties -> Instrument Available.
best regards
MIS
Chris B
Re: TekVisa in Visual Basic 2010
Post by Chris B » January 26th, 2012, 9:34 am
It is going to be the visa32.dll. You can find the functions you need specifically i the TekVISA programer manual (or reference card), which would have been included when you installed TekVISA.
With VB, some people prefer to use the ActiveX control instead of directly using visa32.dll. If this is the case, you would use the TVC. Help document for this is labeled TekVISA ActiveX control help.
MIS
Post by MIS » January 26th, 2012, 10:23 am
I use tvc, i can not read the lockState from a device that is in use, there is no message (see also TekXL Toolbar for Excel)
I can not integrate the visa32.dll in Visual Basic 2010, Errormessage: It could not be added referring to visa32.dll. make sure that you can access a file and it is a valid assembly or com component.
Can you give me an example to use visa32.dll in visual basic 2010?
Chris B
Post by Chris B » January 26th, 2012, 11:33 am
VB will not give you direct access to the .dll. If you were using C or C# you could.
Users browsing this forum: No registered users and 17 guests
