remote control the tcpa300 current probe amplifier
Is it possible to remotely control this device. Especially degaussing it?
If it is possible, what it takes?
Re: remote control the tcpa300 current probe amplifier
i suppose where there is a will, there is a way but it'll take a herculean effort. the tcpa300 does not have any official remote control features. range information is sent to the oscilloscope if you are using the tekprobe interface cable but that is it.
I would like to make the herculean effort needed to remotely degauss it.
(It said on the amplifier brochure it can be remote controlled)
How can I do it?
Thanks.
How can I do it?
Thanks.
The TCPA300 current probe amplifier does not have direct remote programming access. If you are using the TEKPROBE to TEKPROBE interface cable to connect the TCPA300 to your oscilloscope, you have some remote control capability through the oscilloscope. You would have access to the time and scale factors of your current measurements. However, degauss can only be performed from the TCPA300 front panel.
Thanks for the help.
