DPO7014 can’t determine saving CSV data range by programming command
s31167
Country: Taiwan
Post by s31167 » June 23rd, 2016, 11:40 pm
When the scope recall length is 50K, I want to save channel 4 full data as csv file.
Trying the command as below:
data:stop 50000;
SAVe:WAVEform:FILEFormat SPREADSHEETCsv;
SAVe:WAVEform CH4,"C:\CH4";
But I always got 20K data length , not 50K that I set.
I have looked for the programming manual P.439.
In the manual, it could be use “DATa: STARt and DATa: STOP” command to determine what range I want to save.
But in real, it not so.
Or what command could change the attachment - red block value?
Scott H
Re: DPO7014 can’t determine saving CSV data range by programming command
Post by Scott H » June 28th, 2016, 7:56 am
Hello s31167,
The DATa:STARt and DATa:STOP commands are supposed to set the saved waveform range but this is a bug that was found after the scope was discontinued. A work around is to use the CURVe? command. The difference between "SAVe:WAVEform" and "CURVe?" is that SAVe:WAVEform will save the file to the scope while CURVe? will return the values to the PC. Then the PC running the script will have to save the results as a csv. Below is an example of the commands to send
DATa:ENCdg ASCIi
DATa:SOUrce CH4
DATa:STARt 1
DATa:STOP 50000
values = CURVe?
C#
System.IO.File.WriteAllLines(@"C:\Temp\Results.csv", values);
Matlab
fid = fopen('Results.csv', 'w+');
for i=1:size(values, 1)
fprintf(fid, '%s ', values(i,:));
end
fclose(fid);
