Cannot send commands to my Oscilloscope
Jaspan
Country: United Kingdom
Post by Jaspan » July 22nd, 2016, 2:37 am
I'm trying to send commands to my DPO 2024B, however, it will only respond to queries. for instance, when i send;
cout << scope.sendCommand("DATa:SOUrce?");
it will tell me its reading from Channel 1, however, if i send;
scope.sendCommand("DATa:SOUrce CH1");
It takes this as a bad command, and crashes the USB, giving "nothing returned" for all queries and needs the USB to be physically re-set.
This happens with every command that i send, although sometimes when it crashes, it stores the command, and then runs it next time. For instance, the command;
scope.sendCommand("HEADer ON");
Crashes it, but if i subsequently run;
scope.sendCommand("HEADer?");
It will place headers by all my outputted queries.
Any help or comments would be greatly appreciated, I've only been doing this for a couple of weeks.
Many thanks,
Adam
Jaspan
Re: Cannot send commands to my Oscilloscope
Post by Jaspan » July 22nd, 2016, 8:43 am
I think the problem is in the object 'scope', the manual states that i need to send an EOM (End of Message) command after the line. so i'm trying to terminate each line at the end of 'sendCommand'.
To do this, i need the ascii command for end of line; i've tried 04 (End of Transmission), 25 (End of medium) and 13 - 10 (CR - LF) but none of these seem to work.
does anyone know the ascii command for EOM?
Post by David N » July 27th, 2016, 1:38 pm
Not sure of your exact programming environment. Appears that you are writing code in C++. If you are using a Visa library, you may want to look at some example remote instrument examples we have in the “Remote Instrument Communications Examples” forum group. They are at: viewtopic.php?f=580&t=133570.
