Taking repeated Single Sequence Data
needhelp
Post by needhelp » September 21st, 2016, 12:41 pm
I need to record repeated (~500) single sequence data from the TDS3014(b), without having to manually set the scope into single sequence and into acquisition mode every time
Re: Taking repeated Single Sequence Data
Post by David N » September 21st, 2016, 3:35 pm
The TDS3014B does not have this capability, if I understand your inquiry. Once you perform a single sequence acquisition, you have to re-arm the scope for a new acquisition. If the data recording rate is slow, you could perform this via programmatic control.
An example can be found in the "Remote Instruments Communications Examples" in the forum. viewtopic.php?t=136170.
