MDO 3014 Visual C++ program cannot save waveform data
ucmcob
Post by ucmcob » December 24th, 2016, 6:14 pm
I'm programming a VC++ program to remotely control our MDO 3014 (via USB port) to acquire a single waveform, then transfer the waveform data to PC disk and save it as .csv format.
I can see the waveform acquired successfully from oscilloscope screen. But the data cannot be saved to PC. I've tried different ways to save the data, unfortunately, no one works.
Any suggestions are appreciated!
Thanks.
int main(void)
	ViSession rm = VI_NULL;
	ViSession vi = VI_NULL;
	ViStatus status = 0;
	ViChar	buffer[256] = {};
	ViUInt32 retCnt;
	// Open a default Session
	status = viOpenDefaultRM(&rm);
	if (status < VI_SUCCESS) goto error;
	// Open the usb device
	status = viOpen(rm, "USB::0x0699::0x0408::B010275::INSTR", VI_NULL, VI_NULL, &vi);
	// Set timeout to 5 seconds
	status = viSetAttribute(vi, VI_ATTR_TMO_VALUE, 50000);
	//Turn on channels 1
	status = viWrite(vi, (ViBuf) ":SELECT:CH1 1", 50, &retCnt);
	//Set aquire mode to SAMPLE
	status = viWrite(vi, (ViBuf) ":ACQUIRE:MODE SAMPLE", 20, &retCnt);
	status = viWrite(vi, (ViBuf) ":ACQUIRE:STOPAFTER SEQUENCE", 27, &retCnt);
	//Set CH1 as the source
	status = viWrite(vi, (ViBuf) ":DATA:SOURCE CH1\n", 17 , &retCnt);
	//Set encoding to ribinary
	status = viWrite(vi, (ViBuf) ":DATA:ENCDG SRIBINARY\n", 22 , &retCnt);
	//Set the data to collect
	//TODO:: set the data to start at 1 and stop and record length
	status = viWrite(vi, (ViBuf) ":DATA:START 1\n", 14 , &retCnt);
	status = viWrite(vi, (ViBuf) ":DATA:STOP 10000\n", 17 , &retCnt);
	//Set the destination to REF1
	status = viWrite(vi, (ViBuf) "DATA:DESTINATION REF1", 22 , &retCnt);
	//Set the number of bytes
	status = viWrite(vi, (ViBuf) "WFMOUTPRE:BYT_NR 1", 20 , &retCnt);
    	//Set waveform save format to SPREADSHEET
	status = viWrite(vi, (ViBuf) "SAVE:WAVEFORM:FILEFORMAT SPREADSHEET", 40, &retCnt);
	//Get the curve
	status = viWrite(vi, (ViBuf) "CURVE?\n", 8, &retCnt);
	status = viWrite(vi, (ViBuf) ":SAVE:WAVEFORM REF1, \"ref1.csv\"", 100, &retCnt);
	status = viWrite(vi, (ViBuf) ":SAVE:WAVEFORM CH1, \"ch1.csv\"", 100, &retCnt);
	status = viWrite(vi, (ViBuf) "SAVE:WAVEform ALL, \"all.csv\"", 100, &retCnt);
	viClose(rm);
	return 0;
error:
	// Report error and clean up
	viStatusDesc(vi, status, buffer);
	fprintf(stderr, "failure: %s\n", buffer);
	if (rm != VI_NULL) {
		viClose(rm);
	system("pause");
	return 1;
Re: MDO 3014 Visual C++ program cannot save waveform data
Post by David N » January 3rd, 2017, 10:15 am
There are several remote programming examples in the "Remote Instrument Communication Examples" forum group at: viewforum.php?f=580. You may find one of them helpful to your programming situation.
tekzilla
Post by tekzilla » January 4th, 2017, 5:03 am
The SAVE:WAVEFORM command saves the selected waveform(s) to the scope's internal memory, not to the controlling computer.
The best way to get waveform data to the controlling computer programmatically is to use the CURVE? query, which I see you've written in your script. Sending the CURVE? query to the scope causes it to put the current waveform data into a buffer and send that data to the controlling computer. You'll use a viRead() command to transfer the data from the buffer to a variable in your program. The CURVE? query returns data in the IEEE 488 binary block format, which prepends a short header onto the data (See http://na.support.keysight.com/pna/help ... alyzer.htm and scroll down to the "Block Data" section for more details).
Once you've got the waveform data stored as a variable in your program, you can manipulate and save it however you like on your computer.
