HowLn I readback the limit Test result by c# via TekVisa
dutdut82
Country: Singapore
Post by dutdut82 » January 19th, 2017, 1:39 am
I have just bought a Tektronix TDS2012C scope for a test system. It will be used to measure a waveform with limit test feature.
To make the test automatically, I am planning to integrate the tekvisanet library to the test application (c#).
Do you have any sample code for the tekvisanet?
Re: HowLn I readback the limit Test result by c# via TekVisa
Post by David N » January 19th, 2017, 8:36 am
There is a forum post at viewtopic.php?t=137065 that has come example of using Tekvisanet. This should help you get started.
Dave W
Post by Dave W » February 1st, 2017, 3:31 pm
Hi dutdut82,
Since you are using C# I would recommend using NI-VISA as your VISA layer. TekVISA is only offered with a COM interface which will work in C#, but is not as easy to use a native .NET interface. NI-VISA has a native .NET interface and good documentation to go along with it making it pretty easy to use.
http://www.ni.com/download/ni-visa-16.0/6184/en/
