Acquisition of all channels from oscilloscope
violem
Country: Italy
Post by violem » February 23rd, 2017, 2:43 am
Hi, I am working at a Visual C++ routine to acquire the traces from all the 4 channels of my oscilloscope DPO 70404C. The script runs on the oscilloscope as virtual gpib.
What I did so far is creating a MFC dialog based application that gets the curve from just ONE channel, read the stored array from ref memory and write it in a txt file.
The function that i used to read the waveform is basically the same (with some small modifications) as in FORMATIO.CPP programming example in the Tektronix Programmer manual.
My question is:
which is the best way to loop the same function to retrieve the curve on the 4 channels?
Thanl you very much
w2aew
Re: Acquisition of all channels from oscilloscope
Post by w2aew » February 23rd, 2017, 11:36 am
My colleague that does a lot of programming for the scopes suggests that you simply encapsulate your code that grabs one channel into a function that you can pass a parameter (channel number) to, then simply call this function four times - once for each channel.
violem
Country: Italy
Post by violem » February 28th, 2017, 5:43 am
Thanks a lot for your hint,
Cheers
