Python 3 FastFrame Summary Frame Transfer
tekzilla
Post by tekzilla » June 6th, 2017, 1:21 pm
This program acquires 10 frames of a FastFrame acquisition, creates a summary frame that averages all the other frames together, transfers the waveform data from the summary frame to the computer, and plots the correctly scaled waveform. You will have to change the horizontal, vertical, and trigger settings (time/division, sample rate, volts/div, vertical offset and position, trigger type, trigger threshold, etc.) as they relate to your specific signal.
https://github.com/tkzilla/visa_control ... example.py
VISA Control: FastFrame Summary Frame Transfer
Author: Morgan Allison
Date Created: 6/2014
Date Edited: 5/2017
This program acquires 10 instances of a pulse train that contains a
periodic runt using FastFrame and transfers the summary frame to the computer.
Windows 7 64-bit, TekVISA 4.0.4
Python 3.6.0 64-bit (Anaconda 4.3.0)
NumPy 1.11.2, MatPlotLib 2.0.0, PyVISA 1.8
To get PyVISA: pip install pyvisa
Download Anaconda: http://continuum.io/downloads
Anaconda includes NumPy and MatPlotLib
Download SignalVu-PC programmer manual: http://www.tek.com/node/1828803
Tested on Tested on DPO5204B, MSO72004, and DPO7104C
import visa
import numpy as np
import matplotlib.pyplot as plt
def get_waveform_info():
    dpo.write('acquire:stopafter sequence')
    dpo.write('acquire:state on')
    dpo.query('*OPC?')
    binaryFormat = dpo.query('wfmoutpre:bn_fmt?').rstrip()
    print('Binary format: ', binaryFormat)
    numBytes = dpo.query('wfmoutpre:byt_nr?').rstrip()
    print('Number of Bytes: ', numBytes)
    byteOrder = dpo.query('wfmoutpre:byt_or?').rstrip()
    print('Byte order: ', byteOrder)
    encoding = dpo.query('data:encdg?').rstrip()
    print('Encoding: ', encoding)
    if 'RIB' in encoding or 'FAS' in encoding:
        dType = 'b'
        bigEndian = True
    elif encoding.startswith('RPB'):
        dType = 'B'
        bigEndian = True
    elif encoding.startswith('SRI'):
        dType = 'b'
        bigEndian = False
    elif encoding.startswith('SRP'):
        dType = 'B'
        bigEndian = False
    elif encoding.startswith('FP'):
        dType = 'f'
        bigEndian = True
    elif encoding.startswith('SFP'):
        dType = 'f'
        bigEndian = False
    elif encoding.startswith('ASCI'):
        raise visa.InvalidBinaryFormat('ASCII Formatting.')
    else:
    return dType, bigEndian
"""#################SEARCH/CONNECT#################"""
# establish communication with dpo
rm = visa.ResourceManager()
dpo = rm.open_resource('TCPIP::192.168.1.14::INSTR')
dpo.timeout = 10000
dpo.encoding = 'latin_1'
dpo.write_termination = None
dpo.read_termination = '\n'
print(dpo.query('*idn?'))
dpo.write('*rst')
dpo.query('system:error:all?')
"""#################INITIALIZE VARIABLES#################"""
# variables for individual settings
hScale = 200e-9
sRate = 2.5e9
numFrames = 10
vScale = .2
vPos = 0
hiThresh = 0.4
lowThresh = 0.2
"""#################CONFIGURE INSTRUMENT#################"""
# dpo setup
dpo.write('acquire:state off')
dpo.write('horizontal:mode auto')
dpo.write('horizontal:mode:scale {}'.format(hScale))
dpo.write('horizontal:mode:samplerate {}'.format(sRate))
dpo.write('acquire:mode sample')
dpo.write('horizontal:fastframe:state on')
dpo.write('horizontal:fastframe:count {}'.format(numFrames))
dpo.write('ch1:scale {}'.format(vScale))
dpo.write('ch1:position {}'.format(vPos))
dpo.write('trigger:a:type pulse')
dpo.write('trigger:a:pulse:class runt')
dpo.write('trigger:a:pulse:runt:qualify occurs')
dpo.write('trigger:a:pulse:runt:polarity:ch1 positive')
dpo.write('trigger:a:pulse:runt:threshold:high {}'.format(hiThresh))
dpo.write('trigger:a:pulse:runt:threshold:low {}'.format(lowThresh))
print('Horizontal, vertical, and trigger settings configured.')
# configure data transfer settings
dpo.write('header off')
dpo.write('horizontal:fastframe:sumframe average')
dpo.write('data:encdg fastest')
dpo.write('data:source ch1')
recordLength = int(dpo.query('horizontal:mode:recordlength?').strip())
dpo.write('data:stop {}'.format(recordLength))
dpo.write('wfmoutpre:byt_n 1')
dpo.write('data:framestart 10')
dpo.write('data:framestop 10')
print('Data transfer settings configured.')
"""#################ACQUIRE/PROCESS DATA#################"""
print('Acquiring waveform.')
# dpo.Timeout = 60
dpo.query('*opc?')
print('Waveform acquired.\n')
# Retrieve vertical and horizontal scaling information
yOffset = float(dpo.query('wfmoutpre:yoff?'))
yMult = float(dpo.query('wfmoutpre:ymult?'))
yZero = float(dpo.query('wfmoutpre:yzero?'))
numPoints = int(dpo.query('wfmoutpre:nr_pt?'))
xIncr = float(dpo.query('wfmoutpre:xincr?'))
xZero = float(dpo.query('wfmoutpre:xzero?'))
dType, bigEndian = get_waveform_info()
data = dpo.query_binary_values(
    'curve?', datatype=dType, is_big_endian=bigEndian, container=np.array)
"""#################PLOTS#################"""
# Using the scaling information, rescale the binary data
scaleddata = (data-yOffset)*yMult+yZero
scaledtime = np.arange(xZero, xZero+(xIncr*numPoints), xIncr)
print('Plot generated.')
# plot the figure with correct scaling
plt.subplot(111, facecolor='k')
plt.plot(scaledtime*1e3, scaleddata, color='y')
plt.ylabel('Voltage (V)')
plt.xlabel('Time (msec)')
plt.show()
dpo.close()
