Free Software: TekScope Utility
Locked
Dave W
Post by Dave W » May 7th, 2018, 5:08 pm
Attention:
If you are looking for software that enables you to remotely control your scope, perform off-line analysis of waveforms, multi-scope capability, decoding of waveforms and much more, please see the official Tektronix software TekScope at https://scope.tekcloud.com.
Hi Everyone,
I have release my TekScope Utility to try to help make your life easier fetching data from Tektronix Oscilloscopes, including Windows based oscilloscopes and the new 3, 4, 5 and 6 Series oscilloscopes. With luck, this utility will avoid you having to write your own code!
Please read the description below for details. Download links can be found at the end of this post.
TekScope Utility Screenshot.png (72.43 KiB) Viewed 16704 times
This free software falls under the Tektronix Free Software Download Agreement (See below).
This software is covered under the Free Software Download agreement. Not all free software has gone through Tektronix normal quality control or production processes, but is provided to users as an accommodation to respond to user requests. The free software is provided hereunder on an As-Is basis without any representation or warranty. Tektronix disclaims all warranties, whether express or implied, including warranties of merchantability, fitness for a particular purpose and non-infringement of intellectual property rights. In no event shall Tektronix be liable for any direct, indirect, special, incidental or consequential damages in any way arising out of or connected with the use of the free software.
Getting Support
NOTE: This software IS NOT an official Tektronix product and I am providing this software purely to try to make your lives easier. This means this is not a Tektronix supported piece of software. Do not try to contact technical support for help with this software. They will not help you!
If you need help using the program, please post your support request in the TekScope Utility Support forum thread.
If you find bugs in the program, please post your bug report in the TekScope Utility Bug Reports forum thread.
The threads linked above are the ONLY official locations for support request and bug reports. When you post in them I will be notified of your post by email. This is the only way you can ensure that I see your support request or bug report.
About this Software
TekScope Utility is a Free software utility designed for the transfer of data (screenshots, waveforms etc.) from Tektronix Oscilloscopes to the PC so they may be saved to the PC’s hard disk.
Features Include:
  • Transfer and saving of screenshots (hard copies) from scope to PC (.png, .jpg or .bmp)
  • Transfer and saving of analog waveform data from scope to PC (.CSV)
  • Transfer and saving of digital waveforms data from scope to PC (.CSV)
  • Transfer and saving of measurement data from scope to PC (.CSV)
  • Transfer of scope setups to and from the scope
  • Command console for interactive remote command sessions with instrument
  • Data Logging of scope data to PC over time
Prerequisites
Supported Instruments
The following Instruments are supported by this software.
  • TDS200 Series
  • TBS1000(B)(C) Series
  • TBS1000B-EDU Series
  • TBS2000 Series
  • TDS2000(B)(C) Series
  • TPS2000(B) Series
  • TDS3000(B)(C) Series
  • DPO MSO 2000(B) Series
  • DPO MSO 3000 Series (Firmware Version 2.4 or Later)
  • MDO3000 Series
  • DPO MSO 4000(B) Series
  • MDO4000(B)(C) Series
  • 3 Series MDO
  • 4 Series MSO
  • 5 Series MSO
  • 6 Series MSO
  • DPO MSO 5000(B) Series
  • DPO 7000(C) Series
  • DPO DSA MSO 70000 (B)(C)(D)(DX)(SX) Series
Supported Interfaces
  • Asynchronous Serial (RS-232) COM Ports
  • GPIB (NI 488.2 compatible)
  • Ethernet (VXI-11)
  • USB (USBTMC)
Installation Instructions
  • Download the .zip file to your PC
  • Extract the .zip file to the location of your choice
  • Double-Click "TekScope Utility.exe" to run the application.
Download TekScope Utility
Version 1.2.3.2
TekScope Utility 1.2.3.2 Release Notes.pdf
(157.26 KiB) Downloaded 19 times
TekScope Utility 1.2.3.2.zip
(396.32 KiB) Downloaded 46 times
Version 1.2.2.11
TekScope Utility 1.2.2.11 Release Notes.pdf
(154.82 KiB) Downloaded 65 times
TekScope Utility 1.2.2.11.zip
(394.28 KiB) Downloaded 121 times
Version 1.2.1.1
TekScope Utility 1.2.1.1 - Release Notes.pdf
(153.58 KiB) Downloaded 184 times
TekScope Utility 1.2.1.1.zip
(383.74 KiB) Downloaded 392 times
Version 1.2.0.7
TekScope Utility Release Notes v1.2.0.7.pdf
(152.43 KiB) Downloaded 646 times
TekScope Utility 1.2.0.7.zip
(433.64 KiB) Downloaded 1193 times
Version 1.1.1.4
TekScope Utility Release Notes v1.1.1.4.pdf
(490.75 KiB) Downloaded 814 times
TekScope Utility 1.1.1.4.zip
(739.93 KiB) Downloaded 1066 times
Version 1.1.0.1
TekScope Utility Release Notes v1.1.0.1.pdf
(423.92 KiB) Downloaded 1037 times
TekScope Utility 1.1.0.1.zip
(272.56 KiB) Downloaded 1138 times
lars.winkelmann
Re: Free Software: TekScope Utility
Post by lars.winkelmann » July 11th, 2018, 6:21 am
Hi Dave,
can you add support for TekVisa Devices ?
Dave W
Post by Dave W » July 18th, 2018, 4:04 pm
This program uses the IVI standard VISA.NET interface to keep the program VISA vendor agnostic. Unfortunately TekVISA does not contain a VISA.NET implementation hence why TekVISA does not work. TekVISA needs to be updated to support the VISA.NET interface.
Dave W
Post by Dave W » October 8th, 2018, 4:28 pm
New version 1.1.1.4 has been released. This maintenance release includes the following changes:
  • Added support for Series 6 MSO
  • Fixed FFT MATH waveform transfer failing on some models
  • Fixed issue with hard copy failing over Ethernet on TDS3000B Series
  • Other minor fixes/enhancements
Dave W
Post by Dave W » June 28th, 2019, 3:07 pm
TekScope Utility 1.2.0 Released
After much time sitting in development, TekScope Utility version 1.2.0 has been released!
This new version brings some major new features to TekScope Utility including support for fetching On-Screen Measurement data and Data Logging. Download it from the links in the first post in this thread.
Measurements
TekScope Utility Measurements Tab.png (23.54 KiB) Viewed 7715 times
Data Logging
TekScope Utility Data Log Tab.png (27.91 KiB) Viewed 7715 times
Change Log
TekScope Utility 1.2.0.7 includes the following changes:
  • New Feature: Fetch on-screen measurement data and save to .csv file
  • New Feature: Data Logger
    • Fetch and store scope data automatically on trigger, on timer interval or on both.
    • Stop logging data after time duration, specific date/time or manually
    • Stop logging data after a specific number of events
  • Added ability to automatically connect to an instrument at program startup via command line arguments
    • Create a shortcut to TekScope Utility.exe and add “-a <VISA Resource Address>” to the target.
    • Example: “TekScope Utility.exe" -a TCPIP::192.168.1.4::INSTR
  • Added support for TDS1000C Series oscilloscopes
  • Added support for new 3 Series MDO
  • Added support for new 4 Series MSO
  • Added support for new DPO71604SX and DPO71304SX models
Dave W
Post by Dave W » May 1st, 2020, 2:32 pm
TekScope Utility 1.2.1 Released
New version 1.2.1.1 of TekScope Utility has been released. This maintenance release includes the following changes:
  • Added support for new TBS2000B Series scopes
  • Increased the auto fetch delay value for datalogging on TDS2000 Series and MSO/DPO2000 Series scopes to increase reliability of fetching up to date data.
  • Moved application of standard VISA timeout to be applied directly after opening a connection and increased timeout value to avoid timeouts that users were experiencing when trying to connect to some scope models.
Dave W
Post by Dave W » August 10th, 2020, 6:08 pm
TekScope Utility 1.2.2 Released
New version 1.2.2.11 of TekScope Utility has been released. This maintenance release includes the following changes:
  • Improved reliability when connecting/fetching data from 4 Series instruments.
  • TekScope Utility will now retry connecting if a timeout occurs during the connection process.
  • Fixed an issue where fetching waveforms would timeout on TBS1000B-EDU models.
  • Fixed an issue on DPO70000SX Series instruments with ATI inputs where only CH1 and CH2 were available to fetch waveforms from.
  • Increased the maximum record length allowed for fetching waveforms to 62.5M. Note: Fetching waveforms at these record lengths will use a lot of RAM on your computer.
Dave W
Post by Dave W » September 9th, 2020, 3:24 pm
TekScope Utility 1.2.3 Released
New version 1.2.3.2 of TekScope Utility has been released. This maintenance release includes the following changes:
  • Added support for the new TBS1000C Series scopes
You can download this release from the post at the beginning of this thread.
Locked
