Error code and read with Labview
petitou
Country: France
Post by petitou » January 9th, 2019, 4:59 am
Hello everybody,
I use a Labview programm to acquire and analyze datas from the DPO 7104C Oscilloscope. It works perfectly but now I would like to add new functionalities.
For example, when there is a clipping on the curve, I would like to change the scale (in order to avoid clipping of the signal).
Is the Oscilloscope able to transmit a code to the PC? If yes, what is the error code?
I’ve seen the different labview example and different documentation, but I don’t find the solution.
Thanks a lot in advance!
Re: Error code and read with Labview
Post by David N » January 9th, 2019, 3:42 pm
I would look at the “Execution error messages” that are listed in the programmer’s manual. Possible you can incorporate those detected errors in you code via the SESR register.
petitou
Country: France
Post by petitou » January 21st, 2019, 1:16 am
David, thank you for your response.
How can I communicate with the SESR Register?
Should I send a character chain ? if yes, how write on the register?
Thank you
Post by David N » January 21st, 2019, 8:53 am
Refer to the programmers manual regarding the use of the SESR Register.
