how to trigger over can bus ID with python on mdo4104c?
adegyx
Post by adegyx » March 8th, 2019, 5:24 pm
I read programming manual and setup BUS first; then set up trigger over CAN bus identification.
but when execute the code, it did not trigger
can I ask whether there is any example for this?
thanks
adegyx
Re: how to trigger over can bus ID with python on mdo4104c?
Post by adegyx » March 11th, 2019, 11:00 am
here is my code for bus setting and trigger:
#config CAN BUS
scope.write('BUS:b2:CAN:SOURce CH1')
scope.write('BUS:b2:CAN:bitrate 500000')
scope.write('BUS:b2:CAN:SAMPLEpoint 50')
scope.write('BUS:b2:CAN:PROBe CANL')
#config trigger
scope.write('TRIGger:a:TYPe BUS')
scope.write('TRIGger:a:BUS CAN')
scope.write('TRIGger:a:BUS:SOUrce B2')
#print(scope.query('TRIGger:a:BUS:SOUrce?')
scope.write('TRIGger:MODE NORMal')
scope.write('TRIGger:a:BUS:b2:CAN:CONDition IDentifier')
scope.write('TRIGGER:a:BUS:b2:CAN:IDENTIFIER:MODE STANDARD')
scope.write('TRIGger:a:BUS:b2:CAN:IDentifier:VALUE 1100') #59C
#scope.write('TRIGger:a:CAN:b2:CAN:IDentifier:VALUE 10110011100') #59C
#print(scope.query('TRIGger:a:CAN:b2:CAN:IDentifier:VALUE?)
scope.write('TRIGger:a:STATE ON')
