c# / TekVISA / SEL:CHn requires retry?
Posted: May 8th, 2019, 8:58 am
by cfebrian
I'm writing code to integrate a Fn Gen and a Scope (sine sweep and data collection of a transducer). I'm using:
  • Win 10/64-bit
    c#
    Visual Studio 2019
    TekVISA from NI
I've had limited success. I created a class (classOscilloscopeTektronix) to handle the low level communication. Some methods work... some don't
This method works great:
        public bool IsPluggedIn()
            bool isFound = false;
            TekVISANet.VISA TVA = new TekVISANet.VISA();
            System.Collections.ArrayList instrlist;
            TVA.FindResources("?*", out instrlist);
            foreach (string nameFoundInList in instrlist)
                if ((nameFoundInList.IndexOf(nameScopeModel) != - -1) &&
                    (nameFoundInList.IndexOf(nameScopeVendorID) != -1))
                    isFound = true;
                    nameFound = nameFoundInList;
            TVA.Clear();
            TVA.Close();
            return (isFound);
These (x2) do not:
        public void WriteToScope(string command)
            TVA.Open(nameFound);
            TVA.Write(command);
            TVA.Clear();
            TVA.Close();
        public void WriteToScopeWaitForPrior(string command)
            TVA.Write("*OPC?");
            TVA.Write(command);
            TVA.Clear();
            TVA.Close();
For my unit test, I've tried the code below and not all the channels show up on the display! When I type it in by hand using telnet, it works just fine. Seems like there is some handshaking missing?
        [TestMethod]
        public void TestLowLevelCommunications()
            ClassOscilloscopeTektronix scope = new ClassOscilloscopeTektronix();
            string response;
            scope.WriteToScope("*RST");
            scope.WriteToScope("SELECT:CH2 ON");
            scope.WriteToScope("SELECT:CH1 ON");
            scope.WriteToScope("SELECT:CH3 ON");
            scope.WriteToScope("SELECT:CH4 ON");
So, I tried a variation. This still does not work. In fact, the SEL:CH2? results in false. So, I issued the command and it did not seem to stick.
        [TestMethod]
            string response;
            response = scope.QueryScope("BUSY?");
            while (response.Contains("1"))
            response = scope.QueryScope("SELECT:CH2?");
In frustration, I implemented a retry and this works. However, no other examples on the web seem to show that retries are necessary. What's going on here?
            response = scope.QueryScope("SELECT:CH1?");
