Tektronix PA1000 - Will it measure 480VAC Single Phase?
bhollis
Post by bhollis » January 16th, 2019, 8:33 am
Will the PA1000 measure 480VAc single Phase? And can you use the Breakout box with it?
Re: Tektronix PA1000 - Will it measure 480VAC Single Phase?
Post by David N » January 16th, 2019, 12:58 pm
The PA1000 can measure up to 600 Vrms (Cat II). The breakout box is only rated for 120Vrms for the BB1000-NA model and 240Vrms for the BB1000-EU and BB1000-UK versions. See attached instruction manual for the breakout box.
BB1000-Instruction-Manual.pdf
(918.92 KiB) Downloaded 493 times
