How to add buffers to save R1,R2,R3 to USB
Models 2450, 2460, 2461, 2470
dmeans
Post by dmeans » June 30th, 2022, 7:49 am
I am using a 2461 Source meter. I am very new to all of this, but I was wondering if someone could look at my current TSP file and show me how I can add buffers to store the values of R1,R2,R3 to a USB flash drive.
Main1.txt
(2.86 KiB) Downloaded 16 times
Re: How to add buffers to save R1,R2,R3 to USB
Post by Andrea C » August 2nd, 2022, 8:12 am
See if the sample code from section on Reading and Writing to Front Panel USB helps you.
https://www.tek.com/en/documents/applic ... sing-(tsp)
In your case, you already have variables R1, R2 and R3. You could just directly write them to a file on the thumb drive. No need to first put them into a buffer.
What is your code trying to do? Looks like it needs to do two resistance measurements when forcing 10mA of current. And then do some pass/fail analysis on the values and output a pattern on digital bits.
What changes between the first and second measurement? I note you have a 150msec delay. Is something externally changing the test leads or something?
Return to “2450/2460/2461/2470 Touchscreen SourceMeter”
