open collector PNP/NPN with Keithley 2701
Phil100
Country: Canada
Post by Phil100 » January 26th, 2017, 2:58 pm
Is it possible to use flow sensor with open collector PNP/NPN output with Keithley model 2701.
Re: open collector PNP/NPN with Keithley 2701
Post by Andrea C » January 26th, 2017, 3:27 pm
Possibly. Can you post a data sheet for the flow sensor?
Phil100
Country: Canada
Post by Phil100 » January 30th, 2017, 7:35 am
Here is a link for the operating instructions
http://www.burkert.com/en/Media/plm/MAN ... 0314074EN-
and for the data sheet
http://www.burkert.com/en/Media/plm/DTS ... 0011081ENU
Thank for your support
Post by Andrea C » February 6th, 2017, 5:29 pm
Pg 10 and 11 in the Operating Manual has the wiring diagrams.
Looks like you will use the 2701 freq measure function with your flow meter pulse signal.
You will also need a power supply.
A pulse counter is probably better suited to the rather low frequencies from a flow meter.
