Logging into Sentry generates Video Syntax Errors
fgiannetti
Post by fgiannetti » September 22nd, 2017, 1:27 pm
Hi. We support a customer's video monitoring with two Tektronix Sentrys. One of them generates Video Syntax Errors on most monitored streams whenever someone logs into the Sentry UI. Has anybody seen this before and/or has a solution? The Sentry runs the following:
System Package Version: 2016-069
Sentry Engine: 1498.430
Sentry Database: 10.0.9
Maximum MPEG payload input bitrate 8 Gbps
Simultaneous Stream Captures 4
Simultaneous Stream-to-View 2
Hard Disk Size 1024GB
CPU Model Intel(R) Xeon(R) CPU E5-2630 v4 @ 2.20GHz
RAM 98GB
The second Sentry has less payload, memory, etc., and doesn't experience the issue:
System Package Version: 2016-032
Sentry Engine: 1497.636
Sentry Database: 9.6.23
Maximum MPEG payload input bitrate 500 Mbps
Hard Disk Size 500GB
RAM 12GB
CPU Model Intel(R) Core(TM) i7 CPU 930 @ 2.80GHz
Any suggestions would be appreciated.
Frank
