How to find out that a channel is limited?
Der_Iltis
Post by Der_Iltis » March 8th, 2018, 7:25 am
Dear all,
Today I'm trying to find out that a smu26xx was in compliance during a measurement. I'm ramping voltage at the cathode and measuring current at the cathode and the anode of a diode. My limit of 0.1 mA is clearly reached during this sweep. However, reading status.measurement.condition does not yield any information (status is always 0). How do I query the instrument for the information about the status of a measurement?
Dave W
Re: How to find out that a channel is limited?
Post by Dave W » March 13th, 2018, 1:19 pm
The smuX.source.compliance command will return true or false if the source is in compliance or not. If you are using it in a script then you could add the line
hitLimit = smuX.source.compliance
If you are sending commands to the instrument one at a time then you can send to the instrument
print(smuX.source.compliance)
