How to generate pulse in remote mode until the program stop it?
David_1222
Country: Taiwan
Post by David_1222 » September 17th, 2018, 2:05 am
We use C language to control the Keithley 2611B output pulse in remote mode. The 2611B need to be stop pulse until we finish our optical measurement. However, the whole time is not the same, so we can not use the "Pulse Function" directly which describe in manual.
ConfigPulseIMeasureV (smu,bias,level,limit,ton,toff,points,buffer,tag[,sync_in][,sync_out][,sync_in_timeout][,sync_in_abort])
↑ We need a method without using "points", or how to use "abort".
Other engineer suggest use a loop, and abort when it done. The Qusition is :
1.) How to generate continues pulse?
2.) How to use abort?
