Kithley 6220&2182a Delta setting and connection problem
Heekyung lee
Country: South Korea
Post by Heekyung lee » November 27th, 2018, 5:01 am
I am a newbie of labview and instrument.
I want to execute delta mode using KI6220 and KI2182a and want to measure delta meas only connecting two of them(without pc control).
2182a and 6220 is connected by line rs-232 and other one, and I measured Voltage-Current by using multimeter and sured each of them work well, but i guess they have connection or setting problem.
According to manual, after pressing 'configure' -> 'Delta' button, 6220 should be setted as 'delta' and its display should show letters 'delta'
i did synchronization of them, and set language SCPI, Baud 19.2K following manual.
but they didnt work. i don't know what is the problem. someone please help me...
Re: Kithley 6220&2182a Delta setting and connection problem
Post by Andrea C » December 4th, 2018, 4:56 pm
On 6220, double check the settings for the RS-232.
After you verify them, set the interface back to GPIB.
Press Delta.
Any different?
