Press 'Single' button on oscilloscope programmatically
IceCream
Post by IceCream » December 3rd, 2018, 6:35 am
There is 'Single' button on Tektronix TDS 2024C oscilloscope front-panel.
I cannot find in Programmer Manual how to press this button programmatically.
Please suggest what command should I use.
w2aew
Re: Press 'Single' button on oscilloscope programmatically
Post by w2aew » December 3rd, 2018, 7:19 am
First issue an ACQUIRE: STOPAFTER SEQUENCE
This will setup the Single acquisition.
Then, ACQUIRE:STATE ON will put the scope in Run mode, waiting for the trigger event.
Once the scope triggers, it will be stopped.
To re-arm the Single mode, issue ACQUIRE:STATE ON again...
IceCream
Post by IceCream » February 28th, 2019, 7:45 am
When I set
ACQUIRE:STOPAFTER SEQUENCE
the waveform freezing, then I set
ACQUIRE:STATE ON
it does nothing.
After these commands, when I try to set or query any command it throws timeout exception.
It does not respond to any command.
UPD: As soon as I have written this post I have understood that the problem is because I have not set a trigger. That is why it cannot complete the acquisition. Thank you!
